KVM0108A installation
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • KVM0108A installation
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
EzraBML
EzraBML
Cadet
Posted: ‎2023-01-23 02:12 AM
1510
I am connecting KVM0108A with KVM Console and Dell server.
From Console to KVM0108A I used the VGA cable with USB and another USB cable(TYPE B to TYPE A). and from KVM0108A to Server I used Cat6 ethernet cable. but I cannot get a video feed.
Do we need to buy the APC KVM 2G, Server Module, USB(attached)
bbradley_jaxcon
Lieutenant | EcoXpert Master bbradley_jaxcon Lieutenant | EcoXpert Master
Posted: ‎2023-01-26 04:34 AM
This is a forum for a software product call "SmartConnector." Honestly someone here maybe able to answer your question... but this isn't really the right forum to find out information on KVMs.
Personally, 99% of all the servers I've worked with are VMs these days.... no there is no need for physical hardware.... unless the VMServer is having issues.
MaximeLaudren
Lieutenant MaximeLaudren Lieutenant
Lieutenant
Posted: ‎2023-03-20 11:09 AM
Hi @EzraBML,
As Bbradley said, this forum is for the SmartConnector software.
In regard to your question,
The KVM unit you have need adapter to connect on the server part.
Do not mistaken the physical cable and the data transiting in it.
In you case, it's normal that the KVM does not work, because despite the connection being a RJ45, it is not a network port.
Find attached a sheet with compatible server adapter that will work with you KVM unit, you can pick between different type of adapter depending on the type of connection available on your server: USB/PS2/...
You will also find a quick guide on how the KVM unit should be connected.
Max
