Is there a way to sync between 2 processors?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Is there a way to sync between 2 processors?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-11-01 10:42 AM
721
Is there a way to sync between 2 processors? For example, the update processor should start after the setup processor has completed.
Mike
JeffBowman
Sisko
Posted: ‎2020-11-02 10:41 AM
Hi Michael,
The best way to do this is to utilize the In-Memory Cache feature of Smart Connector.
In your setup processor, you would add an item to the cache, maybe a Boolean with whatever key you want, and then in your update processor, you look for the cache item with that key, and check its value. If it is true, continue the run of the update processor, and if not, end the run of the update processor early.
Best Regards,
-Jeff
JeffBowman
Sisko
Hi Michael,
Best Regards,
-Jeff
