Changing the EWS path
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Changing the EWS path
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2020-11-02 01:21 AM
694
I want to change the endpoint of the EWS Server from "SmartConnectorOPCClientService" to "/EcoStruxure/DataExchange".
Can you please let me know where in the code this should be done?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2020-11-02 10:40 AM
Hi Michael,
In your code there is already a line that is setting the endpoint to SmartConnectorOPCClientService all the developer needs to do is change this one line to /EcoStruxure/DataExchange.
This code is the code that is creating the server most likely in your setup processor.
Best Regards,
-Jeff
JeffBowman
Sisko
Hi Michael,
Best Regards,
-Jeff
