Is it possible to change EWS Server values via the EBO?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Is it possible to change EWS Server values via the EBO?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2019-02-06 12:51 AM
1232
Thanks.
Mike
  • EWS Server
JeffBowman
Sisko
Posted: ‎2019-02-06 06:34 AM
1222
Yup! An EWS SetValues request is sent to the Smart Connector EWS server. Since Smart Connector is the server hosting the data, they must be notified or the values are not changed. Regards, -Jeff
Replies 4
JeffBowman
Sisko
Posted: ‎2019-02-06 04:52 AM
1228
Hi Michael, Yes it is, as long as the EWS Value is a Read/Write point (which is determined when you create the ValueItem in the Smart Connector EWS Server). Regards, -Jeff
mike_meirovitz
Commander
Posted: ‎2019-02-06 06:32 AM
1224
Thank you Jeff,
Is the EWS server notified with the new value once the value is modified via the EBO?
Thanks.
Mike
JeffBowman
Sisko
1223
mike_meirovitz
Commander
Posted: ‎2019-02-06 06:46 AM
Thank you! cool
