Is it Possible for the Processor to Check (Rather Than Ignore) the Case of Alternative IDs?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Is it Possible for the Processor to Check (Rather Than Ignore) the Case of Alternative IDs?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Control-See Software Solutions Ltd
UCME-SmartConnector™
Back to SmartConnector Forum
Lydia
Lieutenant | EcoXpert Master Lydia Lieutenant | EcoXpert Master
Posted: ‎2022-07-20 08:02 AM
1633
Let's say I have two points with two similar Alternate IDs which are the same except for their cases.
1. RootContainer/Siemens TECs/TEC01/AIRFLOW and
2. RootContainer/Siemens TECs/TEC01/Airflow
Unfortunately, when two or more points with alternate IDs which are the same except for their case, I receive the following error:
2022-07-20 10:42:25.1746,Info,WorkerThread,<no principal>,EWS Server,Started,
2022-07-20 10:42:25.2446,Error,Processor,<no principal>,One or more errors occurred.
The AlternateId RootContainer/Siemens TECs/TEC01/AIRFLOW is already in use. AlternateId values must be unique.
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at eDriveSCProcessor.eDriveSCProcessor.Execute_Subclass()
at Mongoose.Process.Processor.Execute(CancellationToken token, ProcessorExecutionMode mode)
,["EWS Server"],
I would like SmartConnector to not ignore the case of the alternative IDs. Is this possible?
  • Thumbnail of UCME-SmartConnector™
View products (1)
Tags (4)
  • case
  • ignore
  • processor
ardak
Posted: ‎2022-07-22 12:35 AM
Hi Lydia,
Out of the box SmartConnector does not support this, but from what I can tell the only thing restricting this is the database collation. If you want to you could try changing it to a case sensitive one, for example
SQL_Latin1_General_CP1_CI_AS -> SQL_Latin1_General_CP1_CS_AS
I have not tested this, so use with caution.
BR
Armend
