Ideal default rates for Throttling Policy in SmartConnector RESTfull gateway
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Ideal default rates for Throttling Policy in SmartConnector RESTfull gateway
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Bayu
Lieutenant JG Bayu Lieutenant JG
Lieutenant JG
Posted: ‎2023-01-09 07:23 PM
1413
We have costumer that utilizing SmartConnector RESTfull EWS Gateway to get data from EBO and they asked can they change Throttling Policy default rates at 100 request/minute to 1200 request/minute? Are there any ideal or maximum rates for this?
BR,
Bayu
MaximeLaudren
Lieutenant MaximeLaudren Lieutenant
Lieutenant
Posted: ‎2023-03-17 03:26 PM
1307
Hi Bayu,
The throttle policy can vary depending on both system capability and application use.
If you have a powerful machine, the throttle level can be high, if the machine is not powerful you will have a low limit.
You have to adjust this based on the CPU/RAM usage of the machine.
If you notice the machine is overloaded and response time is high, reduce the throttle limit.
If the machine is working fine and need a higher capacity, increase the throttle limit.
I'm not sure there is any guideline / directive for this it will depend on both the request done and the machine capabilities.
Max
MaximeLaudren
Lieutenant
1308
Hi Bayu,
Max
Bayu
Lieutenant JG
Posted: ‎2023-03-19 09:44 PM
Hi Max,
Thanks for your explanation..
Bayu
