How to connect over CSP to a server.
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How to connect over CSP to a server.
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
LucasHawk
Lieutenant JG LucasHawk Lieutenant JG
Lieutenant JG
Posted: ‎2018-12-18 11:49 AM
1370
I am just getting started (again), and trying to write a simple chunk of code to connect to a server and print its alarms, over CSP. The following is what I have:
namespace SmartConnector.MongooseConnectCSP
    public class MyTestFixtureFixture : SmartConnectorTestFixtureBase
        #region FixtureOneTimeSetup_Base - Override
        //protected override void FixtureOneTimeSetup_Base()
        //    SmartConnectorService.InitIoC();
        #endregion
        #region MyTest
        [Test]
        static void Main()
            var client = MongooseObjectFactory.Current.GetInstance<IManagedCspClient>();
            Assert.IsNotNull(client);
            var server = new CspEndpoint
                Address = "X.X.X.X",
                Password = "thePassword",
                UserName = "theUser"
            //var verison = NativeClient.ServerVersion(server);
            //Assert.IsNotNull(version);
            var response = client.RetrieveAlarmEvents(server, new CspQuery()
                IncludeHidden = true,
                IncludeSystemFolderWhenSearching = true
            Assert.IsNotNull(response);
            Debug.Print(response.ToString());
            throw new NotImplementedException();
        #endregion
When I try to run this (just using the debugger in VS2017), I get the following error:
System.IO.FileNotFoundException: 'Could not load file or assembly 'StructureMap, Version=3.1.4.0, Culture=neutral, PublicKeyToken=5cb6388d33b04e56' or one of its dependencies. The system cannot find the file specified.'
Any help?
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2018-12-31 10:08 AM
Hi, that error suggests something more trivial than a code error, it's not specific to CSP.
Do you have a reference to the Mongoose.Service.exe file in your Test project? - If you do, make sure the StructureMap, Version=3.1.4.0 dll is in the same folder. You may also need to check that the package version you have from Nuget is a match with your installed version of SmartConnector (particularly if this is prior to the 2.4 release)
