How to connect arduino to plc schneider m221 hardware via rs232
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How to connect arduino to plc schneider m221 hardware via rs232
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Logic Controller - Modicon M221
EcoStruxure™ Machine Expert - Basic
Back to SmartConnector Forum
Posted: ‎2022-07-29 10:41 PM
I want to communicate from arduino to plc via rs232. I have made settings on the arduino and with the help of the modbus tester it is known that "Read Ok" means that the data has been sent from the arduino. However, after setting up the PLC m221 machine basic expert via a serial line modbus IO scanner with the slave address and offset that has been set but the value for %iwn when commissioning is an error or is red. Based on the error code from %iwns100 the error is because "Device not scanned correctly due to a communication error detected on a channel of the
device." Do you have any suggestions on how to make random values ​​generated in the Arduino program read in the PLC program? thankyou
  • Thumbnail of EcoStruxure™ Machine Expert - Basic
  • Thumbnail of Logic Controller - Modicon M221
View products (2)
Replies 0
