Hello everyone
Currently I have established a SOAP REST Provider through SmartConnect
Also in the Swagger UI website http://localhost//swagger/docs/v1.1 I successfully see the value read
But if I use other methods to read, it currently fails.
For example I used Node Red and tried to read http://localhost/Root
The result is 405
Can anyone share with me other methods of successfully reading data?
Thanks in advance
Hi ToneLu, first you need to get a bearer token using the /GetToken method. The Swagger interface has a token generator on the page, but to integrate your application, you need to get a token and include it in the header of your requests.
To get a token, you need to POST http://<EndpointAddress>:<rPort>/GetToken
In the request header add:
Add the following keys to the message body / payload:
The response will include the token.
Thanks Reply
I did successfully get the Token
I also successfully read the value
