How to Activate SQL Microsoft Reader Extension License in Smart Connector 2.5
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • How to Activate SQL Microsoft Reader Extension License in Smart Connector 2.5
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Adham_zaki
Lieutenant | EcoXpert Master Adham_zaki Lieutenant | EcoXpert Master
Posted: ‎2025-09-14 08:42 AM
Hello Community,
I need your support with the activation of the SQL Microsoft Reader Extension for SmartConnector 2.5.
My Case
  • I already purchased both licenses:
    • Runtime License – PN: SXWSWSCDL100001
    • SQL Microsoft Reader Extension – PN: SXWSWSCEXT0090
  • The runtime license was successfully activated:
    • I accessed smartconnectorserver.com, selected SmartConnector 2.5 runtime, added my order details, downloaded the .lic file, and applied it using mongoose.exe.
    • This worked fine — I can see the runtime license active.
  • The SQL Extension license is the issue:
    • I cannot find any option on smartconnectorserver.com to generate the .lic file for the extension.
    • If I add the extension license manually through the License Administrator, it appears in the list, but it does not show in the SmartConnector web interface (localhost:8082).
    • I searched EcoXpert and Community resources but could not find any documentation that explains the steps for extension licenses.
My Questions
  1. How can I correctly add the SQL Microsoft Reader Extension entitlement (PN: SXWSWSCEXT0090) to SmartConnector 2.5?
  2. Is there an official guide or documentation that explains how to generate or apply the .lic file for SmartConnector extensions?
  3. Does the SQL extension activation follow a different process from the runtime license activation (since licensing is unified with EBO in SmartConnector 2.5)?
Replies 0
