Hej Fredrik,
You are correct, EBO will not update(rediscover) your EWS server. This means that dynamic structures like the one you are describing can't be used.
I guess there are several ways of tackling this limitation, but the easiest that comes to mind is maybe representing every room as a string value. This way, you could store a JSON representation that could get updated, and your bookings would be a list in the JSON value.. something like this:
Then you could have a script program parsing them and doing whatever you need to do in EBO.
Hope this helps,
Armend
Hej Fredrik,
Hope this helps,
Armend
