SmartConnector crashes and the following error is displayed. Any idea how to fix it without reinstalling SmartConnector?
2022-04-13 21:34:05.2889,Error,Service,<no principal>,HTTP could not register URL http://+:57621/DataExchange/ because TCP port 57621 is being used by another application.
The process cannot access the file because it is being used by another process
at System.ServiceModel.Channels.SharedHttpTransportManager.OnOpen()
at System.ServiceModel.Channels.TransportManager.Open(TransportChannelListener channelListener)
at System.ServiceModel.Channels.TransportManagerContainer.Open(SelectTransportManagersCallback selectTransportManagerCallback)
at System.ServiceModel.Channels.TransportChannelListener.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.HttpChannelListener`1.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at System.ServiceModel.Dispatcher.ChannelDispatcher.OnOpen(TimeSpan timeout)
at System.ServiceModel.ServiceHostBase.OnOpen(TimeSpan timeout)
at Mongoose.Service.Mongoose.SpinUpEwsServerHost(EwsServer server)
Thanks.
Mike
Hi Michael,
It does, there's a checkbox for "Add sample data" in the installer. You can use another port, or if it bothers you, delete it.
BR
Armend
Hi Michael,
Like the error message says, 57621 is already used by something on your system. If you haven't restarted your computer after reinstalling, try that, or use available tools to find out what is using the port.
BR
Armend
Hi Armend,
Thank you for your answer. This port is used by the Weather EWS Server sample that is installed by default.
It would be nice if the SmartConnector will have an option to install or not install this sample EWS server.
Mike
Hi Michael,
BR
Armend
