GET /Trends using RESTfull EWS Gateway
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • GET /Trends using RESTfull EWS Gateway
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
petri_greenwave
Lt. Commander | EcoXpert Master petri_greenwave Lt. Commander | EcoXpert Master
Posted: ‎2017-05-04 06:30 AM
949
Hi All,
We have successfully pulled data from some logs in a test environment but now need to go into this a bit deeper.
I know the GET/Trends is not supported in SoapEwsRestProvider but this is exactly what we need to do next. We want to get a list of trend logs in the system.
Apart from the GET/Trends which is not supported, is there any other way we can do this? Currently we run a query in SQL to get all the trends but then manually have to add them to the code.
Also will future versions support this? Where is the limitation?
  • gettrends
sesa180908_brid
Commander
Posted: ‎2017-05-04 06:47 AM
Petri,
The RESTful EWS Gateway API was designed in a provider agnostic manner.  As a result, it was known that not all Providers would be able to support all methods.
The limitation for the SoapEwsRestProvider is that it uses EWS under the covers and EWS doesn't allow a way to "get all Trend Logs in a system" in one call.  The only workaround is to browse the object tree yourself.  As you can imagine this could be a very chatty endeavor and that is why it wasn't considered as a workaround for the provider.  In contrast, the MongooseEWsRestProvider has direct DB access to its data source so it can easily support this method.
Current development on a native SBO provider should alleviate this restriction.  This will of course be a different provider, but it will use the exact same API.
