GET TrendSamples/{id} not work
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • GET TrendSamples/{id} not work
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
XiangfengSU
Lieutenant JG XiangfengSU Lieutenant JG
Lieutenant JG
Posted: ‎2020-06-18 02:58 AM
2056
SmartConnector + EBO3.0
When I used GET /TrendSamples/{id}, it returned the TrendSample id not found. But the id was from GET /TrendSamples.
the Response of GET /TrendSamples
the response of GET /TrendSamples/{id} with the above id:
JeffBowman
Sisko
Posted: ‎2020-06-22 01:51 PM
2024
Hello!
Smart Connector 2.4.24 was just released which contains the fix for this issue.
Best Regards,
-Jeff
Replies 9
Erwin-vd-Zwart
Janeway
Posted: ‎2020-06-18 03:01 AM
2055
You need to URL encode the TrendID and use it as ID
BR,
Erwin
XiangfengSU
Lieutenant JG
Posted: ‎2020-06-18 03:05 AM
JeffBowman
Sisko
Posted: ‎2020-06-18 06:38 AM
2042
Hi Xiangfeng,
It looks like you have configured an SboEwsRestProvider (based on the Trend ID). This provider tends to be pretty quirky, and it is not recommended to use unless there is a very specific need.
Please try and reconfigure a new endpoint using the SoapEwsRestProvider and try this again.
Best Regards,
-Jeff
XiangfengSU
Lieutenant JG
Posted: ‎2020-06-18 06:36 PM
2039
Hi, JeffBowman
    I have reconfigured another endpoint with SboEwsRestProvider. But the problem still exists.
JeffBowman
Sisko
Posted: ‎2020-06-18 06:45 PM
2037
Hi Xiangfeng,
Please configure a SoapEwsRestProvider.
Best Regards,
-Jeff
XiangfengSU
Lieutenant JG
Posted: ‎2020-06-18 07:00 PM
2035
Hi, Jeff
    With SoapEwsRestProvider, the problem is the same.
BR,
Su
JeffBowman
Sisko
Posted: ‎2020-06-22 11:42 AM . Last Modified: ‎2020-06-22 12:47 PM
2030
Hi Xiangfeng,
I tested this locally and was able to reproduce your issue. I have also come up with a fix for the issue, and will work on rolling out a new version of Smart Connector that contains this fix (this is specifically about the /TrendSamples/{id} issue.
Best Regards,
-Jeff
JeffBowman
Sisko
2025
Hello!
Best Regards,
-Jeff
XiangfengSU
Lieutenant JG
Posted: ‎2020-06-22 06:40 PM
Thank you very much, Jeff
