Error when modifying an EWS Server ValueItem in the EBO
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Error when modifying an EWS Server ValueItem in the EBO
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-04-07 08:22 AM
1835
When I try to modify an EWS value in the EBO, I get the following error:
gSoap communication error
Communication
SOAP-ENV:Receiver."http://schemas.microsoft.com/net/2005/12/windowscommunicationfoundation/dispatcher":InternalServiceF...
CWS Client Plugin
12
The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework SDK documentation and inspect the server trace logs.
In the SmartConnector log file, I see this error:
2021-04-07 18:05:26.5671,Error,EwsServe,admin,Object reference not set to an instance of an object.
at SmartConnector.EBOOPCClient.OpcClientManager.WriteItem(EBOOpcItem& opcItem, Object newVal, Boolean bTriggerGrp)
at SmartConnector.EBOOPCClient.EwsServer.CustomSetValuesProcessor.SetValue(ValueTypeStateless item)
at Ews.Server.Contract.Processor.SetValuesProcessor.ProcessRequest_Subclass(SetValuesRequest1 request)
at Ews.Server.Contract.Processor.RequestProcessorBase`2.ProcessRequest(TRequest request)
,[18,"4f4caebb-b1dc-44e5-a89c-6488cd03f3d8"],
2021-04-07 18:05:26.5671,Info,EwsServe,admin,{"Method":"SetValues","Duration":"13"},
2021-04-07 18:05:26.5671,Debug,EwsServe,admin,{"Response":null,"Duration":"13"},
 Any idea what is causing this error?
Thank you.
Mike
JeffBowman
Sisko
Posted: ‎2021-04-07 08:25 AM
Hi Michael,
From the stack trace, it looks as though the error is coming from your custom code:
I don't know what this code does exactly, so I don't have enough information to advise what could be the issues. (e.g. which object could possible be null)
Best Regards,
-Jeff
JeffBowman
Sisko
Hi Michael,
Best Regards,
-Jeff
