Error "Cannot GET /SBO/swagger/ui/index" while trying to open the Swagger interface
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Error "Cannot GET /SBO/swagger/ui/index" while trying to open the Swagger interface
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-05-10 06:42 AM
2166
We have a customer that is getting the error below while trying to open the Swagger interface (http://127.0.0.1:8083/SBO/swagger/ui/index) .
In addition, the SmartConnetcor log file shows the following error:
2021-05-10 11:09:43.5335,Error,Service,<no principal>,Exception has been thrown by the target of an invocation.
El proceso no tiene acceso al archivo porque está siendo utilizado por otro proceso
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at Microsoft.Owin.Hosting.ServerFactory.ServerFactoryAdapter.Create(IAppBuilder builder)
   at Microsoft.Owin.Hosting.Engine.HostingEngine.Start(StartContext context)
   at Mongoose.Service.Mongoose.SpinUpRestProvider(RestConfiguration configuration, MongooseDbContext db)
Any idea what is causing this error?
Thank you.
Michael
JeffBowman
Sisko
Posted: ‎2021-05-18 07:17 AM
2158
Hi Michael,
I believe this issue has been resolved. Is this the case?
Best Regards,
-Jeff
JeffBowman
Sisko
2159
Hi Michael,
Best Regards,
-Jeff
mike_meirovitz
Commander
Posted: ‎2021-05-18 07:29 AM
Yes. It was resolved.
Thanks.
