Error,Processor,<no principal>,An error occurred while updating the entries. The DELETE statement conflicted with the REFERENCE constraint "FK_dbo.Ews
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Error,Processor,<no principal>,An error occurred while updating the entries. The DELETE statement conflicted with the REFEREN...
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2022-08-01 11:13 PM
Our customer in Chile is facing an exception in SmartConnector. See below.
2022-08-01 15:13:46.3962,Debug,EwsServe,admin,{"Response":{"GetNotificationResponse":{"SubscriptionId":"9E7521CC227D4575940D79DE08DCB36E","NotificationId":"5D101BBCB88D42E79D6B230371F7358B","MoreDataAvailable":false,"MoreDataRef":null,"Events":{"AlarmEvents":null},"version":"1.2"}},"Duration":"448"},
2022-08-01 15:13:46.6080,Error,Processor,<no principal>,An error occurred while updating the entries. See the inner exception for details.
The DELETE statement conflicted with the REFERENCE constraint "FK_dbo.EwsNotifications_dbo.EwsSubscriptions_SubscriptionId". The conflict occurred in database "SmartConnector.Service", table "dbo.EwsNotifications", column 'SubscriptionId'.
The statement has been terminated.
at System.Data.Entity.Internal.InternalContext.SaveChanges()
at System.Data.Entity.Internal.LazyInternalContext.SaveChanges()
at Mongoose.Service.Data.MongooseDbContext.SaveChanges()
at Mongoose.Service.Data.MongooseDbContext.Mongoose.Common.Data.IDataSource<Mongoose.Ews.Server.Data.EwsContainerItem>.Save()
at Mongoose.Ews.Server.Data.EwsServerDataAdapter.Purge_Internal(Boolean purgeUsers)
at SmartConnector.EBOOPCClient.SetupProcessor.Execute_Subclass()
at Mongoose.Process.Processor.Execute(CancellationToken token, ProcessorExecutionMode mode)
,["EBO-OPC Client Setup Processor"],
Can you please advise?
See the attached SmartConnector log file.
Thank you.
Mike
Replies 0
