Enterprise Central Soap REST Interface
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Enterprise Central Soap REST Interface
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Evren
Lt. Commander Evren Lt. Commander
Lt. Commander
Posted: ‎2020-08-13 09:20 PM
1690
We have a critical and large project with single EC; multiple ES and several SmartX controllers (AS-Ps).
Question:
If we deploy SoapEwsRestProvider@ EC; would that be able to expose all the objects under ES and ASPs?
Supplementary Question:
Assuming we can deploy multiple smart connectors and target different objects or servers to improve the performance of the SC; given that all the children objects are visible under EC?
@Farhang @Anonymous user
Tags (5)
  • ebo
  • enterprise central
  • rest
  • soap
Evren
Lt. Commander
Posted: ‎2020-08-18 05:15 PM
1678
Question:
Confirmed that the answer is True. EC will expose objects from children.
Evren
Lt. Commander
1679
Question:
JeffBowman
Sisko
Posted: ‎2020-08-19 07:33 AM
Looks like you ran some tests on your own :). You are correct!
Best Regards,
-Jeff
adam_files_ente
Lieutenant | EcoXpert Master adam_files_ente Lieutenant | EcoXpert Master
Posted: ‎2024-04-12 06:53 AM
Evren,
Sorry to wake an old thread -
What path did you use to expose those objects? I see not definitions for this in existing documentation and cannot get the smart connector to function through an EC to an ES (whereas the connection direct to the ES before worked fine)
Thanks!
