Endpoint stops responding after Windows Update
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Endpoint stops responding after Windows Update
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
APA
Lieutenant APA Lieutenant
Lieutenant
Posted: ‎2023-02-08 03:50 AM
1547
Our customers SmartConnector broke after windows update. And swagger documentation ULR returns following message.
He has checked that the service and endpoint is running and that the port is open.
Any ideas?
Replies 5
Carl_Slack
Captain Carl_Slack Captain
Captain
Posted: ‎2023-02-08 07:21 AM
I have had to log in and stop and restart the service via localhost:8082 both on the Endpoint and EWS server. Hope that helps.
APA
Lieutenant
Posted: ‎2023-02-17 12:49 AM
1486
This did not solve the problem, thanks anyway.
Customer whitelisted some IP addresses and did not contact me again. Maybe system updates enforced new firewall policies or something.
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2023-02-19 07:38 PM
Edit the endpoint and click the 'validate' button. It looks like it doesn't like the IP address that you have configured for your host. It could be that the IP address of the server it is running on has changed.
BJC
BJC
Cadet
Posted: ‎2023-02-22 08:44 AM
I can't read your error message clearly, but we suffered a SmartConnector crash recently when a security update to the Windows server outlawed the use of http, swapping to https cured the issue. Maybe worth a look at this?
Daniel_Cerone
Lieutenant JG Daniel_Cerone Lieutenant JG
Lieutenant JG
Posted: ‎2023-07-25 05:52 AM
if there was a net framework update, roll back and try again.
/dcer
