EWS connection error with SmartConnector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EWS connection error with SmartConnector
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
ivan22
Ensign ivan22
Ensign
Posted: ‎2021-08-30 09:52 AM
975
I have an EWS communication error with the SmartConnector, can someone please support me.
I attach some images of the configuration that I have.
configuration on the EBO
configuration the SmartConnector
ardak
Posted: ‎2021-09-12 10:59 PM
From what I can see you are trying to start a Smartconnector EWS server on port 83. This port is in use in your system. You'll have to reconfigure and try again.
2021-08-30 13:59:29.0400,Status,Service,<no principal>,Starting EWS Server http://192.168.10.121:83/EcoStruxure/DataExchange,
2021-08-30 13:59:29.1820,Error,Service,<no principal>,HTTP no pudo registrar la direcci�n URL http://+:83/EcoStruxure/DataExchange/ porque otra aplicaci�n est� usando el puerto TCP 83.
El proceso no tiene acceso al archivo porque est� siendo utilizado por otro proceso
BR
Armend
ardak
Posted: ‎2021-08-30 10:27 PM
964
It looks like you are trying to connect to a Smartconnector EWS server with EBO.
Did work and stop working or are you trying to set it up?
Go to %ProgramData%\SmartConnector\Logs and upload the relevant log output here.
BR
Armend
ivan22
Ensign ivan22
Ensign
Posted: ‎2021-09-01 07:50 AM
958
Hi @ardak
If it is what I want to connect an EWS with the SmartConnector, I cannot connect it, I attach the logs
I hope you can support me.
Regards
2021-08-28.log
2021-08-30.log
ardak
BR
Armend
