EWS RESTful EWS Gateway binding with HTTPS
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EWS RESTful EWS Gateway binding with HTTPS
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2018-02-01 11:58 AM
1943
I'm supporting a customer with securing an endpoint of the EWS Restful Gateway. They have a signed certificate and we are following the notes in the installation guide but seem to be running into some issues. Before I check further I wanted to validate if the correct app id to be binding the certificate with is 596e502c-7957-4a02-8167-716d19ced67f which I have used before to secure the portal.
I wondered if the rest endpoint may come from a different class library and therefore have a different id to bind to.
Tags (4)
  • api
  • endpoint
  • https
  • rest
Replies 5
sesa180908_brid
Commander
Posted: ‎2018-02-01 12:08 PM
Adam,
The REST endpoints are all spun up from the Mongoose.Service.exe service in a manner that is the same as that of the Portal or a native EWS Server.
The code for the REST extensions does reside in a different assembly though - (Ews.RestExtensions.dll).
I would have expected those instructions (for the Portal) would also be applicable and work for the REST endpoints.
I'm not familiar with that GUID.  Where did you get it from?
Adam_Summers
Lt. Commander
Posted: ‎2018-02-01 12:22 PM
1886
Hi Mark I took that out of the installation guide P87/88.
I just realised though that we were trying to bind with the local network IP and not 0.0.0.0 which I had done before. Perhaps this was the error so I'm going to check back and will let you know.
netsh http add sslcert ipport=0.0.0.0:8082 certhash= a0f4288e6f511c295362e570dcbf845c0c9247 appid={596e502c-7957-4a02-8167-716d19ced67f} - has that changed in the latest version?
A quick scan of the app id for the assembly Ews.RestExtensions appears to be 7c6feb6c-e1cf-4198-a534-b6b2a1ee9f06 so I may try this too. I recall at least when I build my own Rest Extension as a processor standing up Web.API methods I needed to use the app id of my own assembly and not the SmartConnector server.
sesa180908_brid
Commander
Posted: ‎2018-02-01 12:26 PM
1886
I don't think we ever changed the Guid of the Service.  But if we did it might have been when we changed the service name (during the 1.3 - 2.0 revision update).  The current GUID for the Service is 0268946a-3985-46f9-a9c2-cd4016ac6ddb.
The one you listed is the one for the Ews.RestExtensions.dll but I would think that the GUID you would use is still the service GUID (above).  Since that's whats actually spinning up the endpoint and hosting it.
Adam_Summers
Lt. Commander
Posted: ‎2018-02-01 12:38 PM
1886
Thanks Mark, will give this a try and report back for future reference in the community. I think that may need a check in the documentation to make sure the correct app guid is listed.
Thanks.
Adam
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2020-02-17 12:45 AM
Did anyone successfully set up a REST Endpoint for EBO that supports HTTPS? We have a project where we need to integrate with a third party over the customers network and they have requested that we use HTTPS. Are there any problems doing this? Is there a step by step guide? I see posts from people who have tried it but not so sure they were successful.
