EBO alarms containing @(MonitoredObject->NAME) in the alarm message are not converted in SmartConnector
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • EBO alarms containing @(MonitoredObject->NAME) in the alarm message are not converted in SmartConnector
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
EcoStruxure™ Building Operation
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2021-12-15 10:18 AM
1842
We have a SmartConnector extension that is receiving alarms (in real-time) from the EBO. We have a problem with EBO alarms that contains the "@(MonitoredObject->NAME)" in the alarm message field. See the attached screen capture.
So for example, if the alarm message is:
@(MonitoredObject->NAME) is in alarm
or the reset message is:
@(MonitoredObject->NAME) has reset
The Smart connector receives the text "@@(MonitoredObject->NAME) is in alarm" instead of D-TMP606-01-00 is in alarm".
Is there something we can change in our SmartConnector extension code to convert the @(MonitoredObject->NAME) to the same value that is displayed in the EBO watch window - "D-TMP606-01-00 is in alarm" or "D-TMP606-01-00 has reset"?
I appreciate a quick response since a customer is waiting for a solution.
Mike
  • Thumbnail of EcoStruxure™ Building Operation
View products (1)
ardak
Posted: ‎2021-12-15 09:56 PM
I'm not sure I fully understand. Some assumptions:
  • Your alarms are showing "@(MonitoredObject->NAME) is in alarm" and the corresponding reset message for every alarm, for every monitored object?
  • You want "@(MonitoredObject->NAME)" to change to the monitored object name, like "Temperature sensor" or "D-TMP606-01-00" ?
In that case, provide the code you are using to activate the alarms,
--Armend
ardak
--Armend
