Does anyone have a code snippet on how to use HistoryItemReader
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Does anyone have a code snippet on how to use HistoryItemReader
JeffBowman
Sisko JeffBowman Sisko
164
ardak
34
sesa180908_brid
34
mike_meirovitz
Commander mike_meirovitz
21
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2017-02-02 06:57 AM
1135
My objective is to obtain trend logs on an AS using SmartConnector.
1. Does anyone have a code snippet on how to use HistoryItemReader?
2. Does EwsServerDateAdapter.HistoryItems get me all the trend logs available on an AS or ES?
Thank you!
Tags (3)
  • ews
  • historyitemreader
  • historyitems
Adam_Summers
Lt. Commander Adam_Summers Lt. Commander
Lt. Commander
Posted: ‎2017-02-02 07:07 AM
1053
Hi Maneesh,
I take this approach, using a retry method since we have some problems with Authentication caused by SBO!
var fails = 0;
var maxRetries = 5;
using (var historyItemReader = new HistoryItemReader
                HistoryItemsToRead = <YOUR LIST OF TREND LOG IDS>,
                EwsEndpoint = EndpointAddress,
                UserName = UserName,
                Password = Password,
                TimeFrom = <START DATE>,
                TimeTo = <END DATE>
                //SBO is not good with the authentication from SmartConnector you often need a couple of retries!
                while (fails < maxRetries)
                    try
                        var dataRead = historyItemReader.ReadData();
                        if (dataRead.Success)
                            foreach (var historyItem in dataRead.DataRead)
                                CheckCancellationToken();
                                //DO WHAT EVER YOU WANT WITH THE HISTORYITEM OBJECT
                        else
                            Logger.LogError("Failed to read log items");
                        break;
                    catch (ApplicationException historyApplicationException)
                        Logger.LogError(LogCategory.Processor, historyApplicationException);
                        fails++;
Replies 7
sesa180908_brid
Commander
Posted: ‎2017-02-02 07:01 AM
1053
I'll try to get a sample out later but I wanted to clarify one part of your question.
The EwsServerDataAdapter is used for SmartConnector EWS servers and not SOAP based servers (like an AS or ES).
The HistoryItemReader is used for SOAP based servers.
Adam_Summers
Lt. Commander
1054
Hi Maneesh,
var fails = 0;
var maxRetries = 5;
                TimeTo = <END DATE>
                    try
                        else
                        break;
                        fails++;
sesa180908_brid
Commander
Posted: ‎2017-02-02 07:16 AM
1053
Adam,
Could this be the HTTPs issue with SBO and EWS rather than an authentication issue?  Although perhaps I'm splitting hairs.
Adam_Summers
Lt. Commander
Posted: ‎2017-02-02 07:21 AM
Yes perhaps! Although I have issues with and without proxy server configuration and also when using http and https! A retry method seems to work just fine and a second attempt almost always works!
Thought it was worth pointing it out for Maneesh anyway. You have the detail in the release notes Bug #348 should anyone want the full explanation!
sesa180961_brid
Lieutenant
Posted: ‎2017-02-02 07:40 AM
1053
Thanks for the code on HistoryItemReader.
The reason I was thinking of using EwsServerDataAdapter is to get HistoryItems' Ids from the AS to pass to the HistoryItemReader.
Assuming that I have to get the HistoryItems Ids, what would be the way to do it?
sesa180961_brid
Lieutenant
Posted: ‎2017-02-02 07:42 AM
Assuming that I have to get the HistoryItems Ids from an AS, what would be the way to do it?
sesa180961_brid
Lieutenant
Posted: ‎2017-02-02 12:31 PM
Found it. I use ExtractHistoryItemIds() method in EwsClient to get the History Item Ids from an AS.
