Does EwsClient.ExtractHistoryItemIds return only Interval Trend Log Ids?
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Does EwsClient.ExtractHistoryItemIds return only Interval Trend Log Ids?
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
sesa180961_brid
Lieutenant sesa180961_brid Lieutenant
Lieutenant
Posted: ‎2017-02-10 10:18 AM
948
I am using the latest version (2.2.108.0) of EwsClient library from Nuget and communicating to SBO ES 1.8.1.
Does EwsClient.ExtractHistoryItemIds() return only Interval Trend Log Ids?
Is there a different method to get Extended Trend Log Ids?
Please find attached the Extended Trend Logs folder structure I have.
Export ExtendedLogs 2017-02-09 143611.xml.zip
Tags (2)
  • ews
  • historyitems
JeffBowman
Sisko
Posted: ‎2017-02-10 11:30 AM
915
Hi Maneesh,
I can't say for sure by looking at your ET log folder, but I know that SBO will not expose Trend Log items that have no records in them OR Trend Logs that are not bound to some sort of value.
When I send a GetContainerItems (which is what ExtractHistoryItems does), I received the follow error for all the logs in your export:
            <EWSv121:ErrorResult>
               <EWSv121:Id>03/Server 1/ExtendedLogs/RackMonitor Logs/DFW35_S140/DFW35 Ste140 AvgHum_AE Log</EWSv121:Id>
               <EWSv121:Message>INVALID_REFERENCE</EWSv121:Message>
            </EWSv121:ErrorResult>
Are you binding your Extrended Trend logs to a Trend Log that is currently bound to a value? And are there any records in your extended trend logs?
-Jeff
JeffBowman
Sisko
916
Hi Maneesh,
-Jeff
sesa180961_brid
Lieutenant
Posted: ‎2017-02-10 12:14 PM
I will check with the site engineer and let you know if everything expected by EWS is correct.
