Can't Retrieve alarms
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • Can't Retrieve alarms
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
Lee.Prasson
Lee.Prasson
Cadet
Posted: ‎2024-04-23 08:03 AM
794
since Alarms  bulk retrieve is not working, i retrieve AlarmEvents and use AlarmEvent.AlarmId to do a RetrieveByIdAsync for each Alarm.
I just get 404 Not found, I made  sure that the AlarmId is double UrlEncoded but still same problem.
C# .Net
#Restful Ews Gateway
SteveGregory
Commander SteveGregory Commander
Commander
Posted: ‎2024-04-29 03:34 AM
1
757
Don't confuse get alarm and get an alarm event. They are two different things. Get alarm gets the information about the alarm object and to retrieve that, you need the id of the alarm object, not the id of the alarm event that is created when the alarm object goes into alarm.
Lee.Prasson
Lee.Prasson
Cadet
Posted: ‎2024-05-02 02:21 AM
Hello Steve,
Thanks for your reply and hints 🙂
 the Alarm object id which i have to use to retrieve infos about the alarm isn't the AlarmId atribute of the alarmevent object ?
    "AlarmId": "02/Server/xyz/133rtgf4181",
    "Acknowledgeable": 1,
    "OccurredOn": "2024-05-02T10:38:16Z",
    "LastTransitionedOn": "2024-05-02T10:38:16Z",
    "Message": " ",
    "Priority": 80,
    "State": 1,
    "Type": "",
    "AlarmSourceName": "",
    "Id": "02/server/xyz/15568d4f1"
because this is what i'm using in the Get Alarms/{id} endpoint to get the Alarm object but i still get 404 not found.
the curl looks like :
curl -X GET --header 'Accept: application/json' --header 'Authorization: Bearer ******' 'http://localhost:8083/Alarms/02%2FServer%2Fxyz%2F133rtgf4181
response : "Message": "Alarm Id 02/Server/xyz/133rtgf4181 not found"
Thanks in advance 🙂
kindly
