Hi Jeff,
I have upgraded my SmartConnector Configuration processor to version 2.4.7. SmartConnector version is also 2.4.7 on my machine. AutomationClientInterfaces login api is throwing run time exception. Please advise.
My code (Second line, Login function is throwing exception–
AutomationClientInterfaces _aci = new AutomationClientInterfaces(iAdvanced: true, iOnlineSession: true, iSession: true, iNavigate: true, iHyperlink: true);
_aci.OnlineSession.Login($"https://{SboServer.Server}:{SboServer.Port}", SboServer.Username, SboServer.Password, SboServer.Domain).Throw();
Exception --- {"Method Login failed. Login failed. ServerVersionsNotCompatible "}
Source - "SE.WorkStation.Automation.Interface" string
Trace "=== exception from automation ===\r\nMigrationException ' Login failed. ServerVersionsNotCompatible'\r\n at SE.WorkStation.Migration.MigrateSession.LogIn(Uri uri, String userName, String password, String domain)\r\n === inner exception ===\r\n InvalidOperationException 'Login failed. ServerVersionsNotCompatible'\r\n at SE.WorkStation.Migration.MigrateSession.LogonToServer(Uri uri, String userName, String password, String domain)\r\n" string
Thanks!
Neeraj Tomar
Hi Neeraj,
I don't think this is an issue with Smart Connector. But it is likely an issue with the WorkStation SDK version you are using. Please upgrade these assemblies to the 2.0.X version.
-Jeff
