An error occurred while executing the command definition. SHUTDOWN is in progress.
SmartConnector Forum
  • EcoStruxure Building
  • SmartConnector
  • An error occurred while executing the command definition. SHUTDOWN is in progress.
JeffBowman
Sisko JeffBowman Sisko
164
sesa180908_brid
34
ardak
34
Back to SmartConnector Forum
mike_meirovitz
Commander mike_meirovitz
Commander
Posted: ‎2022-04-28 12:47 AM
3584
One of our customer (Schneider Electric Sweden) is having an issue with SmartConnector. It is crashing with the error below.  See also the attached log file.
An error occurred while executing the command definition. See the inner exception for details.
Login failed for user 'NT AUTHORITY\SYSTEM'.
Cannot continue the execution because the session is in the k_ill state.
Any idea what is causing this?
Mike
2022-04-27.log
ardak
Posted: ‎2022-04-28 12:58 AM
3580
Hi Mike,
This looks like a database connection issue. I suggest setting Smartconnector up with a user with SQL server authentication or take a look at this thread
If it has worked before and this is a computer managed by Schneider, it's possible that Schneider IT has revised security policies on the computer.
BR
Armend
mike_meirovitz
Commander
Posted: ‎2022-04-28 01:19 AM
Hi Armend,
Thank you for your answer. I have forward it to SE Sweden.
Mike
ardak
3581
Hi Mike,
BR
Armend
mike_meirovitz
Commander
Hi Armend,
Mike
