Adding EWS server value items - performance is deteriorated over time
SmartConnector Forum
Schneider Electric support forum for SmartConnector Framework - enabling custom integrations with EcoStruxure Building Operation, Power Monitoring Expert, and Power Operation.
Select a Country
  • EcoStruxure Building
  • SmartConnector
  • Adding EWS server value items - performance is deteriorated over time
JeffBowman
JeffBowman Champion
171
KarimHussain
KarimHussain Champion
60
ardak
ardak Leader
57
Back to SmartConnector Forum
mike_meirovitz
mike_meirovitz
Mentor
Posted: ‎2021-06-19 06:38 AM
1313
We are using SmartConnector 2.4.38. EBO version is 3.3.
Our EWS Server is creating 10,000 value items. Currently it takes ~17 minutes! to create these value items.  See below how the time it takes to add one items is deteriorated through this process.
After adding 1,000 EWS values the time it takes to create one value is: ~60 milisecond
After adding 2,000 EWS values the time it takes to create one value is: ~65 milisecond
After adding 3,000 EWS values the time it takes to create one value is: ~70 milisecond
After adding 4,000 EWS values the time it takes to create one value is: ~140 milisecond
After adding 5,000 EWS values the time it takes to create one value is: ~119 milisecond
After adding 6,000 EWS values the time it takes to create one value is: ~217 milisecond
After adding 7,000 EWS values the time it takes to create one value is: ~300 milisecond
After adding 8,000 EWS values the time it takes to create one value is: 150~ milisecond
After adding 9,000 EWS values the time it takes to create one value is: ~300 milisecond
After adding 10,000 EWS values the time it takes to create one value is: ~472 milisecond
Two questions:
1. Can you do something to improve this?
2. Can you consider an API that will create large quantity of value items instead one by one?
Thank you.
Mike
ardak
ardak Leader
Leader
Posted: ‎2021-06-21 08:53 AM
1308
Hi Mike,
Thanks for the suggestion! We will add it to our backlog and look into it.
mike_meirovitz
mike_meirovitz
Mentor
Posted: ‎2021-06-21 10:41 AM
Hi Armend,
Thank you for your answer. Any immediate workaround for reducing the 17 minutes time to create 10,000 EWS ValueItems?
Thanks.
Mike
