wiser hub only - is it possible
  • wiser hub only - is it possible
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
adacom
adacom
Cadet
Posted: ‎2024-12-28 12:13 PM
564
i am looking for a simple solution to turn the combi boiler on when out of the house - the 1/2/3 hour boost would answer that question but is that possible without a thermostat in the system - can i set the system up via the app without a thermostat as it is something i wont use - i also dont need to program the heating - i prefer manual control
if thats not possible could i add a trv head and then get access to the app - i have a number of drayton trv's so assume a head would fit one of those - would prefer not to have either a stat or trv head though
thanks
  • Apps
  • Temperature Control
David_SE
Admiral
Posted: ‎2025-03-26 07:57 AM
Hi @adacom ,
Thanks for your post, to full your use case, you can add to your system a RTR (Room Thermostat) or a iTRV.
No need to install the iTRV on a radiator.
BR
David
David_SE
Admiral
Hi @adacom ,
BR
David
