Wiser by SE App - Voice control (Google Assistant)
  • Wiser by SE App - Voice control (Google Assistant)
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
Alfred_SE
Posted: ‎2021-12-22 02:49 AM . Last Modified: ‎2022-01-18 12:39 AM
1
2963
Controlling your smart heating has never been easier!
Voice control (Google Assistant) is a common feature in many homes, so at Wiser, we know that compatibility with virtual assistants like Google assistant is essential for many households. By integrating Wiser with Google assistant, you’ll enjoy hands-free smart heating control using voice commands:
Wiser is the Google Home compatible thermostat that's fully loaded with smart features to save you energy and money, and provide complete comfort and convenience.
Can Google Home Adjust a Thermostat?
Yes! Google Home can adjust your thermostat and let you make changes using voice commands. Wiser is a Google Home compatible thermostat system, follow these steps to start enjoying heating control using the Google Assistant and voice commands with your thermostat:
1. Connect Google Home to your Wiser thermostat system
After setting up the Wiser smart heating system, go to the Google Home app and select Home Control from the Assistant menu. Tap '+' and search Wiser Heat, enter your Wiser log-in to connect your account, assign your Wiser devices to your rooms (and rename if needed) and you're done!
2. Try out some voice commands to check and control your heating with Google Assistant
"Hey Google, what's the temperature in the bedroom?" and "Hey Google, turn the hot water off". You can ask the Google Assistant to tell you what the temperature is in each zone, what you've set the temperature to, boost the heating, increase or decrease your set temperatures, and many more.
Alfred Francis
  • Apps
  • Voice Control
  • Google Assistant
  • Voice commands
Schneider_Community_Team
Lieutenant Schneider_Community_Team
Lieutenant
Posted: ‎2023-10-04 05:46 AM
Useful information on using Wiser with Google Assistant!
Lieutenant
