OpenTherm Mode
  • OpenTherm Mode
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
andyblac
Crewman andyblac
Crewman
Posted: ‎2023-03-30 03:37 AM
6810
OpenTherm Mode
Hi Guy,
I am new to wiser, I went trough the installer but it did ot ask me about fuel type or mode, How do I set mode to OpenTherm ?
 on app version 6.2, this is what it shows in devices.
  • Apps
david101
Crewman david101
Crewman
Posted: ‎2023-03-31 07:47 AM . Last Modified: ‎2023-03-31 07:49 AM
On/off load compensation option is for OpenTherm boilers only.
The control type option has been missing on the app since v6.1 but at least we can now see the heat source type which v6.1 broke but v6.2 fixed.
Replies 11
PhilHornby
Lieutenant PhilHornby
Lieutenant
Posted: ‎2023-03-30 05:46 AM
6802
@andyblac wrote:
How do I set mode to OpenTherm ?  on app version 6.2, this is what it shows in devices.
Next to "Control Type", where you have a ❓, there's supposed to be a ✏️ to click on. The app. I'm using then offers "Relay", "OpenTherm" and "On/Off load compensation" (whatever that is). (I'm sure you know, but OpenTherm requires the appropriate wiring between Hubʀ and Boiler to be in place).
I've fallen back to an ancient version of the App (5.4.2) 'cos the recent releases have been annoying the hėll out of me, as in ("Your house is looking empty, let's get started"...), every time I fire it up 😕
3 Channel Hubᴿ, 13xiTRVs, 8xRoomstats and 2xSmartplug/Repeaters. (UK)
PhilHornby
Lieutenant
Posted: ‎2023-03-30 05:52 AM . Last Modified: ‎2023-03-30 05:55 AM
In response to PhilHornby
@PhilHornby wrote:
"On/Off load compensation" (whatever that is).😕
To answer my own question, I found this explanation .
On/Off load compensation is a proven method of minimising energy use by calculating the demand from a thermostat. As the temperature approaches the required setting, the boiler will fire for shorter periods of time, ensuring a constant temperature is maintained. This not only enhances comfort levels, but also uses less energy. On/Off load compensating products are ideal for use with modern systems in well-insulated houses.
Which is what I thought it did by default anyway!
It transpires it's not available for Oil Boilers - which is why I've never seen it before. Having lied and set my system to Gas Boiler, it's probably a better setting than Relay. What could possibly go wrong? 🤔
andyblac
Crewman andyblac
Crewman
Posted: ‎2023-03-30 06:09 AM
6798
got a call into tech support, it seems it known issue, the issue has been passed to level 2 to fix it.
PhilHornby
Lieutenant
Posted: ‎2023-03-30 06:36 AM
In response to andyblac
If they're trying to say that "level 1" broke it, I doubt it - my money would be on their last firmware roll-out, with the wrong defaults set.  🙄
andyblac
Crewman andyblac
Crewman
Posted: ‎2023-03-30 11:33 AM
6779
well, got another call from tech, said it should be fixed, the app still shows ? but boiler is firing :), and flow temps is not bad
Room Stats seem to give better flow rate than TRV's for some reason. might have to invest in more room stats.
njknh
njknh
Cadet
Posted: ‎2023-03-30 01:49 PM
6771
I'm using App version 6.2 and get the pencil icon next to Control Type, but touching it doesnt do anything, it's just there for decoration. This isnt a problem for me at the moment as I'm operating in the default relay mode.
I do wonder how good/compatible the Wiser Opentherm implementation is giving how poor their firmware and app seem to be, so I think I'll stick with relay mode despite my combi having Opentherm.
andyblac
Crewman andyblac
Crewman
Posted: ‎2023-03-30 01:56 PM
In response to njknh
Looks ok to me getting good low flow rates atm around 37c
david101
Crewman david101
Crewman
andyblac
Crewman andyblac
Crewman
Posted: ‎2023-03-31 07:51 AM
let hope 6.3 fixes it :), my flow rates are not as low as they got in Tado˚ (26˚c), but I can hope Wiser improve thier OpenTherm load demand curves.
krad
krad
Cadet
Posted: ‎2023-09-26 02:09 PM
5904
Hello, I notice you are using HA and have the Wiser app. How did you get the flow return working? I have my Wiser on opentherm but my return temp is showing Unknown.
andyblac
Crewman andyblac
Crewman
Posted: ‎2023-09-28 02:37 AM
In response to krad
it just worked for me,
