Motiondetektor+Dimmer lamp
  • Motiondetektor+Dimmer lamp
David_SE
Captain David_SE Captain
144
Alfred_SE
24
Maude.wiser.
22
Posted: ‎2022-09-30 11:59 PM . Last Modified: ‎2022-10-01 12:07 AM
1263
has a motion detector that should start a light and keep it lit as long as someone moves with a delay time. current function, the light turns on and off when someone moves at different times and intervals
  • Lighting
KevinCetti
Ensign KevinCetti Ensign
Ensign
Posted: ‎2022-10-03 02:00 AM
You have to create 2 automations, 1 for "on" and 1 for "off" then the time setting is adjusted in the motion detectors settings
condition: movement detected.
Action: turn light "on"
next automation
condition: movement undetected
action: turn light "off"
nothing more needs to be added in the automations.
motion detector - settings: delay of registration = adjust the time here for how long the motion detector should stay "on" before it turns light off
Best regards
Kevin
  • 550B1022
  • motion detector
  • pir
  • wiser
KevinCetti
Ensign
next automation
Best regards
Kevin
  • 550B1022
  • motion detector
  • pir
  • wiser
