Is there a way to turn all TRV's on for 1 hour?
  • Is there a way to turn all TRV's on for 1 hour?
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
cotton
cotton
Cadet
Posted: ‎2024-11-24 02:30 AM
736
I would like a method to turn all radiators on for 1 hour regardless of their current temperature, is that possible?
The Boost All function of adding +2C is useful, but there are some scenarios where I'd like a 1 hour boost with all the radiators on full blast for an hour to dry washing etc, is this possible?
At the minute I have to press boost and turn each individual room up which is time consuming, and creating a moment for all the rooms to be 30C would do the trick, but I can't see any way of making that moment last 60 mins only.
Any help would be appreciated.
  • Temperature Control
David_SE
Admiral
Posted: ‎2025-03-28 11:57 PM
hi @cotton  & @BrianT58 ,
Thanks for your post & answer. Today, that feature is not available but i will share your use case with Wiser team.
BR
David
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: ‎2024-11-26 03:43 AM
1
704
Unfortunately in the current App there is no way to do this. If you're are into Home Assistant you could probably do this in there but it's not simple. I'm not aware of any suggestions section of the forum where you could put your Idea maybe @Maude.wiser. can help further with this.
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
cotton
cotton
Cadet
Posted: ‎2024-11-26 08:38 AM
In response to BrianT58
Thanks Brian, thought that'd be the case.
David_SE
Admiral
BR
David
