App schedule wrong since change to BST.
Showing results forΒ
Did you mean:Β
  • App schedule wrong since change to BST.
David_SE
Admiral David_SE Admiral
152
Alfred_SE
24
Maude.wiser.
22
Gortonlad
Gortonlad
Cadet
Posted: β€Ž2024-04-01 03:02 PM
8
3956
Since change to BST Wiser app schedule not updated to BST. This means the central heating and hot water come on an hour earlier than scheduled. Also if I boost the on time is one hour behind. e.g. If I boost water for 1 hour from 9pm the on untill says 9pm, not 10pm. The system time is correct.
  • Apps
  • bug
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-04-10 08:47 AM . Last Modified: β€Ž2024-04-10 12:43 PM
3804
This has now been resolved with the update to v6.9.0 (Android) of the wiser home app.
Regards Brian
(Hub 2, 15 TRV's, 2 rooms stats and 3 extenders)
Replies 8
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-04-03 02:04 AM
I'm gettting the same when I try to boost anything, but it would appear the schedule is being followed and the heating/HW is coming on at the correct times.
I use home assistant and the history on there shows the heating/HW coming on and going off at the correct scheduled time.
Regards Brian
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-04-03 02:40 AM
I'vew emailed support with the issue should get an answer quicker there
Regards Brian
DBT85
DBT85
Cadet
Posted: β€Ž2024-04-04 11:43 AM
I too am suffering the same problem. The app says the time is correct but if at 19:00 you boost for 1 hour, the end time is set to 19:00
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-04-04 11:41 PM
issue has been passed to the Dev team at Drayton Controls, so I'm guessing either an app of hub update at some point.
I can confirm though that the scheduled times are working correctly.
Regards Brian
MarkN
MarkN
Cadet
Posted: β€Ž2024-04-10 08:09 AM
Same problem here.
Time in the Wiser Home App is correct, but if I a "boost" on the heating it's an hour behind.
So a 1 hour boost it says it will finish now. If I do a 2 hour boost it says in will finish in 1 hour.
πŸ™ˆ
BrianT58
Lieutenant BrianT58
Lieutenant
3805
Regards Brian
MarkN
MarkN
Cadet
Posted: β€Ž2024-04-11 02:05 AM
In response to BrianT58
3774
Not sure if it's related to the update to v6.9.0 but I now get "Connction error" while using the Wiser Home app. πŸ™
I have a red light on "Setup" on the hub, and can't remember if that's normal.
I seem to able to connect to "Wiser Cloud Services" from the App and it looks ok.
My Smartphone is connected to the internet.
The Wifi router has power and other devices are connecting OK.
Any ideas???
BrianT58
Lieutenant BrianT58
Lieutenant
Posted: β€Ž2024-04-12 02:34 AM
In response to MarkN
I can only say that mine is now behaving as it should.
Have you got your wiser on a 2.4ghz or 5ghz network? Wiser recommend 2.4.
Regards Brian
Β
