Posted: 2024-10-01 02:45 AM
Is there a any API available to integrate Wiser with Home Assistant?
Posted: 2024-10-02 02:08 AM
There is indeed it's on Github wiserHomeAssistantPlatform/README.md at master · asantaga/wiserHomeAssistantPlatform (github.com)
Works well on my HA
Works well on my HA
Posted: 2024-10-03 03:14 AM
Great info! thank you Mate! I will have a look
Posted: 2024-11-18 05:54 AM
An exemple of using wiser with HA and the Drayton Wiser Integration
Posted: 2024-12-12 02:47 PM
I try to connecte m’y Wiser hub but i can’t find the secret key. When I tried http://192.168.1.XX/secret/ I received an unautorized answer. Could you help me ?
Posted: 2024-12-14 12:15 AM
When your wiser hub is in direct wifi mode ( when you are configuring it ) then with your computer in the ip adress compatible for example 192.168.8.20 you try the dress http://192.168.8.1/secret/.
The response is your secret key, save it because you will be asked for it each time your reinstall the hub in Ha.
https://community.home-assistant.io/t/drayton-wiser-home-assistant-integration/
