Scadapack E-configurator not working
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Scadapack E-configurator not working
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
SCADAPack 300E
DJO74
Ensign DJO74
Ensign
Posted: ‎2021-02-16 06:35 AM
8365
Recently received new laptop with windows 10, installed lateste version of Scadapack E-utilities 8.16.1
But E-configurator is not working and generates an error application event in windows event logger.
Kan activeringscontext voor 'C:\Windows\WinSxS\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_cbf5e994470a1a8f\MFC80.DLL' niet maken. Kan afhankelijke assembly Microsoft.VC80.MFCLOC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50608.0" niet vinden. Gebruik sxstrace.exe voor een gedetailleerde diagnose.
What can I do to resolve this problem?
  • Smart Operations
Replies 16
MartinChartrand
Captain MartinChartrand Captain
Captain
Posted: ‎2021-02-16 08:25 AM
Your best bet for a timely response to your question is to contact our support group at: supporttrss@se.com. They will be glad to assist you.
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-02-16 01:44 PM
8337
You would probably also get a better response rate if you posted the error message in English.
It looks to be an issue with MFC80.DLL, so you could try a Repair of the installation, perhaps this would fix up any issues if the file itself is corrupted.
I would also recommend that you try to set your Win10 OS language settings to English (US), and then retry.  It's possible that E-Configurator has been strong-name matched to a language specific version of the MFC80.DLL.  I haven't ever heard of this being a thing... but it's something quite easy to try.
If this does turn out to be the problem, then it's still worth raising with your local Schneider Tech Support, to get a proper fix for it.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-02-16 02:30 PM
In response to BevanWeiss
8329
This post suggests that you reinstall the VC2005 runtime (you might need to download it separately)
https://social.msdn.microsoft.com/Forums/vstudio/en-US/9ba28069-60c8-4441-abaf-7c7d3467c2ca/error-ca...
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DJO74
Ensign DJO74
Ensign
Posted: ‎2021-02-17 05:49 AM
8297
Thank you for your answers.
The download in the article isn't available anymore but have tried that already.
If the configurator is still build with visual studio 2005 should it not be updated build on a newer platform.
My previous laptop was also windows 10 and set to Dutch as language and had no problems at all.
I tried all but no luck so far.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-02-17 03:22 PM
In response to DJO74
8289
Updated VC2005 Runtime is available here:
https://www.microsoft.com/en-au/download/details.aspx?id=26347
Have you tried changing the language to en-US?
And you should probably provide the log file from sxstrace.exe...
It does look like there's some mixed up versioning in your environment somewhere:
8.0.50727
8.0.50608
You should only have a single version number.
So it would be worth doing a search for VC80 and hiding away any older versions of this.
Probably worth consulting https://support.microsoft.com/en-us/topic/ms11-025-description-of-the-security-update-for-visual-c-2... for what versions of files you should have.  If one file is messed up, then others may be as well.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DJO74
Ensign DJO74
Ensign
Posted: ‎2021-03-01 11:28 PM
8168
Unfortunally that didn't help to.
Also reinstalled all prerequisites but alle with no succes. Configurator does not start and keep getting the windows event error about the MFC80.DLL
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2021-03-02 01:53 PM
8161
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DJO74
Ensign DJO74
Ensign
Posted: ‎2021-03-02 11:42 PM
8152
sxstrace.exe comes up with nothing and says everything is fine.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Posted: ‎2021-03-03 04:11 AM
8147
I believe it's best for you to contact our support group so this won't drag on for you. The email address is in my initial response to your posting.
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DJO74
Ensign DJO74
Ensign
Posted: ‎2021-03-03 04:14 AM
In response to MartinChartrand
8142
Thanks, but they came with the same suggestions as you did and if that didn't work run a VM on which it does work....​
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Posted: ‎2021-03-03 04:22 AM . Last Modified: ‎2021-03-03 04:22 AM
8140
Ok, thanks for the information. I will talk to the support team and see what else can be done in this case.
Martin
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
David_Halstead
Crewman David_Halstead Crewman
Crewman
Posted: ‎2021-03-03 06:17 AM
8134
Hi @DJO74
If you can message me the case number received from e-mailing supportTRSS@se.com as suggested by @MartinChartrand I can look into the case handling and see how the support team can assist further.
Best Regards,
David
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
KevinPosElec
Crewman KevinPosElec
Crewman
Posted: ‎2022-03-31 02:10 AM
In response to David_Halstead
6495
Hello there.
I seem to have the same issue. Did this get resolved.
Many thanks,
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
DJO74
Ensign DJO74
Ensign
Posted: ‎2022-03-31 02:32 AM
In response to KevinPosElec
6484
Unfortunally not. Only thing that works is clean windows set-up and then install the configurator, but if it works after you install other programs I don't know. For me now no option to start with a clean set-up, so if you have a solution i really want to know.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
MartinChartrand
Captain
Posted: ‎2022-03-31 05:27 AM
6471
Hello again.
I'm sorry this hasn't been resolved yet. To bring this to a hopefully successful resolution, please message me the case number from any interaction either of you have had with our support group. I would like to raise this to a higher level of support but I unfortunately can't do anything further without a case number.
Martin Chartrand
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
KevinPosElec
Crewman
Posted: ‎2022-04-03 02:37 PM
Thanks Martin,
I have opened a case.
Case Reference: # 89982666
I only opened a couple of days ago so they haven't had a chance to respond as yet.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
