RemoteConnect reset Input pulse DI1 as Counter 10kHz
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • RemoteConnect reset Input pulse DI1 as Counter 10kHz
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
AlbertoArdila
Lieutenant AlbertoArdila
Lieutenant
Posted: ‎2022-06-08 05:48 AM
2903
Hi
I want to Reset or preset the DI1 configured as Counter 10kHz. The input name is Counter_1
I tried to set Counter_1.VALUE = 0 in the SCADAPackx70 Logic but the counter don't reset.
Can someone tell me how to reset or preset this counter?
Thank you.
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
AlbertoArdila
Lieutenant
Posted: ‎2022-06-13 04:38 PM
In response to richadam
2790
Hi Richadam,
today I called the technician service and they toll me that it is not possible to restart the counter of the input by the Scadapack x70 Logic. It is possible only by the RemoteConnect object.
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 4
richadam
Crewman richadam
Crewman
Posted: ‎2022-06-10 11:39 PM
2841
Did you run simulations to check the output of your case statement? Did you try to reset to see if the count starts? I say this because before the reset, cnt variable will be high impedance z (no value defined)...
gbwhatsapp
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AlbertoArdila
Lieutenant
2791
Hi Richadam,
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-06-15 05:29 AM
In response to AlbertoArdila
What things did you actually try?
I'm pretty sure that I've done this before.  My recollection is that I used an OBJ_WriteField EFB like below:
Did you try this?
The other option is the first doesn't work would be to give a few of the bits in the COUNTER_OBJ_CONFIG a bit of a twiddle.
Schneider obviously need to document/design this interface better.  Resetting counters isn't an unheard of thing, and it should be pretty straight forward (or at least documented).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
jhoncaleb
jhoncaleb
Cadet
Posted: ‎2024-10-30 02:10 AM
Hi Richadam,
Today I spoke with the technician service, and they informed me that resetting the input counter through Scadapack x70 Logic isn’t possible. The only way to restart it is via the RemoteConnect object.
