RemoteConnect MBUS_CommStatus code inquiry
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • RemoteConnect MBUS_CommStatus code inquiry
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
RemoteConnect for the SCADAPack x70
MQuin777
Ensign MQuin777
Ensign
Posted: ‎2023-03-16 06:45 PM
1717
Good evening,
I'm looking for the definition of the MBUS_CommStatus codes on modbus scanners. ex: status 3 or status 4.
Where can I find that?  Haven't been able to in any of the help menus.  Thanks in advance.
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
Joel_Weder
Captain
Posted: ‎2023-03-17 10:58 AM
Hi again El_Gallo,
The Help documentation for RemoteConnect can be a bit challenging to navigate, but the information is indeed there. I've attached a screen capture of the relevant section of the documentation. You'll see that it was found in this area of the RemoteConnect Help:
> Configuration Manuals
  > SCADAPack x70 Configuration
    > Configuring SCADAPack x70 Device Operation
      > Configuring Modbus Operation
        > Configuring Client Operation Using the Modbus Scanner
          > Working With Remote Devices
            > Status And Control Object Details
While the Help documentation can be a bit difficult to navigate , the layout does make sense once you've used it a few times. The Search feature can be quite useful at times as well.
Joel Weder
Remote Operations Specialist
Joel_Weder
Captain
Hi again El_Gallo,
Joel Weder
MQuin777
Ensign MQuin777
Ensign
Posted: ‎2023-03-17 11:43 AM
Joel, you are 100% correct.  Thanks for the detailed answer and the quick reply!
