[Imported] J / K Series Dual Antenna Ports
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • [Imported] J / K Series Dual Antenna Ports
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Trio Licensed Radios
sbeadle
Kirk sbeadle Kirk
Kirk
Posted: ‎2019-10-25 12:05 PM
>>Message imported from previous forum - Category:Trio Data Radios<<
User: joelw, originally posted: 2018-10-16 20:29:35 Id:13
**_jweder:
The J Series and K Series unlicensed radios both have two antenna ports. These can be of great benefit under certain circumstances. The ANT1 port is always used if only one antenna is required, but how and when do you use ANT2?_**
_______________
There are two different ways in which the ANT2 port will come into use:
1) In a radio configured as a Bridge repeater the user may configure the radio as a Dual Antenna Bridge. In this case all communications upstream (towards the Master) will occur on the ANT1 port, and all communications downstream (towards the Remotes) will occur on the ANT2 port. So ensure you connect the antennas appropriately.
It may be desired to have a high gain yagi antenna on ANT1, as the path to the Master is long or obstructed, and more gain is needed. Alternately on ANT2 you may desire to have a low gain omni to communicate with Remotes scattered around the Bridge. Or perhaps a second yagi might be required on ANT2, to communicate with a Remote or Bridge further out.
2) In a radio configured as a Master (Access Point) or Remote the second antenna port may also be enabled. In this case, the radio will always transmit on the ANT1 port, and it will always receive on the ANT2 port. This feature is rarely required, but will be useful in situations where filters or amplifiers are necessary eg in order to overcome losses in cabling and/or filters, or add filters to reduce interference.
  • Radio
Replies 0
