Functions in SCADAPack Workbench vs Functions in SCADAPack x70 Logic
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Functions in SCADAPack Workbench vs Functions in SCADAPack x70 Logic
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
AlbertoArdila
Lieutenant AlbertoArdila
Lieutenant
Posted: ‎2022-01-07 01:48 PM . Last Modified: ‎2022-01-07 01:50 PM
2943
Hi
I am converting a program from Workbench to SCADAPack x70 Logic
In SCADAPack Workbench there are in Lib the Functions and the Functions Blocks
In SCADAPack x70 Logic I use the DBF type to create the functions blocks create in Workbench under Lib / Function Blocks.
My question is: In SCADAPack x70 Logic , where I can create the functions that were created in SCADAPack Workbench under / Lib / Function?  (Not under Lib / Function Blocks)
Thank You
  • SCADA
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
  • Telemetry and SCADA
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-01-07 08:27 PM
2939
The only difference between FB (Function Block) and F (Function) is that the Function Block can carry with it instance data.
The Function must purely be Inputs, Outputs and Temporaries.  It can't have any Private / Public variables associated with it.
My understanding of ControlExpert (aka Logic Editor in RemoteConnect) is that it has the following callable types:
  • Elementary Function
  • Elementary Function Block
  • Derived Function Block
Hence in terms of what the user can create, it is limited to Derived Function Blocks, unless you start to get into development of custom EF/EFB items using the C Language SDK (which I wouldn't recommend).
If you develop a DFB without any instance data, then it should be fine if you just create a single instance of it and reference that everywhere (although you may get compile warnings if you have enabled the duplicate execution of single instance option.. not defaulted enabled).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Replies 5
BevanWeiss
Spock BevanWeiss
Spock
2940
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AlbertoArdila
Lieutenant
Posted: ‎2022-01-12 05:13 AM
In response to BevanWeiss
2925
Hi BevanWeiss
Thanks for the reply
have a good day
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
BevanWeiss
Spock BevanWeiss
Spock
Posted: ‎2022-01-13 03:26 AM
In response to AlbertoArdila
2914
Not sure that you picked the right 'solution' here...
For people coming along later, your message saying 'thanks' isn't going to be very helpful for them (it won't "solve" their query).
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
Joel_Weder
Captain
Posted: ‎2022-01-13 07:41 AM
Just fixed, Bevan. Thanks for pointing it out.
Joel Weder
Remote Operations Specialist
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
AlbertoArdila
Lieutenant
Posted: ‎2022-01-13 08:15 AM
Hi BevanWeiss
I am agree with You, my answer was not complete
I had chosen to create both the FB (Function Block) and F (Function) from Workbench to Derived Function Blocks in SCADAPack x70 Logic
  • scada
  • SCADA app
  • SCADA software
  • SCADA tutorial
