Support forum for Schneider Electric SCADA systems, radios and RTUs. From commissioning integration devices and software, to enhancing existing installations or troubleshooting.
Posted: 2022-01-06 10:06 AM
Hi
In SCADAPAck WorkBench I found the function CURRENT_ISA_DATE that I don’t find in SCADAPack x70 Logic.
The function CURRENT_ISA_DATE with ANY_TO_DINT converts the DATE to the number of seconds.
Line of the code in SCADAPAck WorkBench:
TimeinSeconds := ANY_TO_DINT(CURRENT_ISA_DATE());
Is there a function in SCADAPack x70 Logic that can replace ANY_TO_DINT(CURRENT_ISA_DATE()
I need to calculate the number of seconds passed between two tasks.
Tank You.
Posted: 2022-01-06 11:57 AM
Hi Joel_Weder
Thanks for the reply
I found the function RRTC_DT_MS that gives in the output 2 the number of seconds passed since January 1, 1980, at 00:00.
Have a good day.
Posted: 2022-01-06 11:28 AM
Hello Alberto,
In the RemoteConnect Help, under the Logic Programming Manuals section you will find a group called Real-Time Clock Function Blocks. In that group you will find what you need. For example you could use Time_GetLocal to acquire the number of seconds since the start of the current day. The output is a DINT. So you could store a previous value, then compare it with the most recent value quite easily.
Hi Joel_Weder
Have a good day.
