Failed radio communication
Remote Operations Forum
  • Remote Operations
  • Remote Operations Forum
  • Failed radio communication
Joel_Weder
Captain Joel_Weder Captain
92
BevanWeiss
Spock BevanWeiss
24
sbeadle
Kirk sbeadle Kirk
17
Trio Licensed Radios
GZ
GZ
Cadet
Posted: ‎2020-03-16 02:41 PM
3637
I have a site where the trio E series radio received great (-48dbm) but fails to get data back to the server. Radio appears to transmit but nothing is received, no radio diagnostics nor SCADAPack data while mounted but when the radio is removed from mounts it works great. This has me scratching my head as I am not a radio tech, does anyone got any idea of the cause of this problem? note the VSWR 1.2:1
  • Radio
  • SCADA
  • Telemetry
MartinChartrand
Captain MartinChartrand Captain
Captain
Posted: ‎2020-03-17 05:37 AM . Last Modified: ‎2020-03-17 05:38 AM
In response to GZ
Hello GZ,
It appears your issue would be best suited by our live support team. They can be reached at the following coordinates:
email: supporttrss@se.com
Phone: +1 888-226-6876
Regards and good luck.
Martin Chartrand
SCADA & Telemetry Solution Specialist
Replies 4
Posted: ‎2020-03-16 05:24 PM
Hi Gz. I've just moved your post to the devices section.
Unfortunately we don't have as many Trio guys here as we do ClearSCADA; if you still need a hand please raise a ticket with Support.
I'm no radio tech either, but since it works great off the mounts, it sounds like a grounding problem, or some issue with one of the connections being compromised physically.
LukeEnriquez
LukeEnriquez Cadet
Cadet
Posted: ‎2020-03-17 03:54 AM
2
3612
Hi GZ,
The Trio E-Series has been around for a while (since 2005). I presume this problem has just started in an existing installation, and is not a new installation. If that is the case, it's possible there is a solder joint fault that is occurring when mounted in one orientation (or cable intermittent issue, etc)
When the radio is receiving data (indicated by the Rx/Sync LED), what is the color of the LED? It should be solid green indicating data is being successfully. Where are you located - maybe we could call and run you through some diagnostics.
Cheers
Luke Enriquez
Trio Radio Senior Global Offer Manager
GZ
GZ
Cadet
Posted: ‎2020-03-17 04:14 AM
In response to LukeEnriquez
1
3610
Hi Luke,
Yes the radio problem has only appeared in the last couple of weeks at an existing site,
  • As for a radio issue, I have tried a couple of other radios and have the same issue with them.
  • the radio appears to transmit from the point of view of the LEDs on the radio but no diagnostics in SCADA or site data in SCADA
  • VSWR 1.2:1
I am thinking it is a cable or antenna now, I have a cherry picker coming tomorrow, test/replace them if needed
It has been thought to be a ground loop, but I am not sure what loop would look like
Thanks GZ
MartinChartrand
Captain
In response to GZ
Hello GZ,
Martin Chartrand
