📌 Which product can I customize and how?
Pushbuttons, Switches, Legends, Control stations Customization Forum
Create aesthetic and ergonomic operator interface by personalizing pushbuttons, indicator lights, selector switches, control stations or legends. Discuss with users and experts to get the most of our Harmony selection and configuration tools.
  • Industrial Automation
  • Pushbuttons, Switches, Legends, Control stations Customization Forum
  • 📌 Which product can I customize and how?
Eric_GR
Lieutenant JG Eric_GR Lieutenant JG
8
D_Champ
Ensign D_Champ Ensign
3
GuillaumeMOLINAS
Ensign GuillaumeMOLINAS Ensign
3
Harmony XB4
Harmony XB5
Harmony XALD
Back to Pushbuttons, Switches, Legends, Control stations Customization Forum
Eric_GR
Lieutenant JG
Posted: ‎2021-05-26 07:09 AM . Last Modified: ‎2023-12-04 07:44 AM
5
7810
  • Push Buttons Caps, Plastic Bezel, Selector Switch Label, Boxes, .... and more:
    PBC.PNG     PB.PNG     SSL.PNG    B.PNG.............
  • See pdf file in attached (Customization_Customer_Journey)
  • See pdf file in attached (Customization&Robustness)
  • See pdf file in attached (Customization_Customer_examples)
How I can customize my products
How to replace discontinued marking and legend offers with customized product?
When the sales are stopped on a catalog reference with marking, a solution is to switch to a customized reference.
To avoid having to design it by yourself, this has already been done by me.
I propose you to find in the attached file the correspondence between discontinued references and new customized references. It will be enriched each time new replacement customized references are created.
See Substitution ref in attached.
To place one order see here page 4:
https://community.se.com/krefy84679/attachments/krefy84679/harmony-control-customization-forum/10/7/...
  • Control stations
  • Legend panels
  • Legends and accessories
  • Pushbuttons
Replies 5
Christian16
Crewman Christian16 Crewman
Crewman
Posted: ‎2021-11-30 04:50 AM
7228
Is it possible to customize ATEX control station (XAWF130EX)?
If yes, could you confirm that the ATEX certificate is still valid?
Thanks for your help
Jean-Marie
Jean-Marie Schneider Alumni (Retired)
Posted: ‎2021-11-30 04:53 AM
In response to Christian16
7225
Hello Christian,
XAWF is not customizable for now  : only XALD and XALK control boxes can be customized for now
Christian16
Crewman
Posted: ‎2021-11-30 05:40 AM
In response to Jean-Marie
7221
Thanks for your quick answer.
What about using a legend panel for XAWF130EX ATEX control station?
- Where can I find the cut-out for this enclosure (XAPA cut-outs are available in Tips & Tricks but nothing for XAPM or XAWF)?
- Is the ATEX certification still valid with the legend panel?
Best Regards,
Christian
Eric_GR
Lieutenant JG
Posted: ‎2021-12-09 01:40 AM
7167
Official position about this Topic:
Adding non-metallic components (including legend panel) to an ATEX enclosure should follow IEC 60079-0 rules, more specifically the article 7.4 concerning the electrostatic charges.
Regarding the ATEX enclosures XAWF* group (IIc) and their protection level (Gb) and regarding the nature of the legend panel plastic and its thickness, the surface of the label would be limited to 2000 mm² to keep ATEX certification.
In conclusion, it is not possible to propose a legend panel even for the smallest enclosure XAWF130EX
You will not find legend panel cuts for the ATEX enclosure
Christian16
Crewman
Posted: ‎2021-12-09 02:10 AM
In response to Eric_GR
Thanks for this clear answer!
