Send InviteCancel
2024-12-1011:02 PM
t300 cant read double point
I couldn't read double points from the PM2230 or another brand/model energy analyzer. There was no problem in the p2230 because there were 32-bit versions of 64-bit data, but there is no such option in other brands. In t300 web register does not give any error The value appears to be 0 always.
I believe I have done the definitions correctly, but it doesn't work. Can you help?
hu-250 firmware v2.9.3-4542
Active Energy Delivered (Into Load)
Y
Y
Y
Y
Y
3204
Wh
4
INT64
I wrote 3203 because there is 1 offset in the register table
