Saitel DP - IEC 101 protocol: what is the maximum number of masters/slaves supported?
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Saitel DP - IEC 101 protocol: what is the maximum number of masters/slaves supported?
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
17
Back to Protection & Control
Ivan_Puškaš_EC
Lieutenant Ivan_Puškaš_EC
Lieutenant
Posted: ‎2021-10-05 11:22 PM . Last Modified: ‎2024-07-05 01:15 AM
1477
Dear all,
For the Saitel DP with CPU SM_CPU866e + SM_SER what is the maximum number of master and also slave devices for IEC101 protocol that Saitel can support?
Also, where we can find documentation for any of the particular protocol. In user manual for SM_CPU866e it refers to additional documents, bit I can not find it.
IEC101 user manual FTE-S854-I1D
IEC104 user manual FTE-S854-I4D
IEC103 Master user manual FTE-S854-I3D
IEC61850 Ed1 user manual FTE-S854-IEC61-1
IEC61850 Ed2 user manual FTE-S854-IEC61-2
and more...
For start it would be great to have user manual for IEC101.
Best regards,
  • Saitel range
TomBerry
Lieutenant JG TomBerry Lieutenant JG
Lieutenant JG
Posted: ‎2021-10-05 11:45 PM
The documents for communication protocols for Saitel and T300 RTUs are included with the Easergy Builder configuration tool.
TomBerry
Lieutenant JG
