Saitel DP & WebUI
Protection & Control
Send InviteCancel
2023-01-3104:42 AM
Saitel DP & WebUI
Hi all,
Does Schneider have some recommended and/or tested solution for touch display similar to Harmony Magelis HMIs on which WebUI runtime for Sailtel DP can be started?
If not, any recommendation which 3rd party device touch display can be used? Does anyone have some project where touch display on the front of the cubicle and Saitel DP with Web UI was implemented?
