Share Your Feedback – Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us enhance search functionality and deliver the results you need faster and more accurately. Click here to take the survey Thank you for helping us build a better Community experience!
Hello everyone,
In one future project, the end user would like to have some HMI that will display information from Saitel locally (in cubicle where Saitel will be mounted). We are looking for some HMI that can display Saitel DP, maybe over Saitel's Web Browser or some other solution.
If anyone had a similar situation, any suggestion or solution would be helpful.
Thank you in advance.
Hi Milica,
Although there is no official physical screen linked to Saitel DP, the embedded webserver application is the standard user interface for Saitel DP. it is accessible through any modern Javascript & HTML5 compatible browser.
We've tested this functionality with smartphones, tablets and PCs. We are now trying to validate it with a lean Magelis offer that runs a web browser directly.
Hi Milica,
@Iván_González thank you for the answer.
Can you also tell me on which model of Magelis you are trying to validate it?
Thanks in advance.
