SAITEL DP - CPU866e: IEC 61850 Ed1 and Ed2 certificates?
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • SAITEL DP - CPU866e: IEC 61850 Ed1 and Ed2 certificates?
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
milica_dukic_
Ensign milica_dukic_
Ensign
Posted: ‎2020-10-05 02:24 AM . Last Modified: ‎2024-07-05 12:59 AM
4402
Hello everyone,
I need IEC 61850 Ed1 and Ed2 certificates for SAITEL DP CPU866e (KEMA or similar). I've already have these ones (attached files), but they aren't specifically for SAITEL DP CPU866e. If someone have them, please post them here.
Thanks in advance.
  • Application cases
  • Saitel range
Tags (3)
  • iec 61850
  • Saitel DP
Iván_González
Lieutenant Iván_González Lieutenant
Lieutenant
Posted: ‎2020-10-05 02:51 AM
4395
Of course! I'll post it on this thread. thanks for your patience.
Replies 8
Iván_González
Lieutenant
Posted: ‎2020-10-05 02:39 AM
4397
Hi Milica,
The certification process for IEC 61850ed.2 in Saitel DP CPU866e is ongoing right now. Hope to have fresh documents to publish by next month.
milica_dukic_
Ensign
Posted: ‎2020-10-05 02:50 AM
4397
@Iván_González  thank you for the answer.
Please post it here when it becomes available.
Milica Dukic
Iván_González
Lieutenant
4396
Milica_Repac
Lieutenant JG Milica_Repac
Lieutenant JG
Posted: ‎2020-12-25 06:00 AM
4364
Hello Iván_González,
You've said that the certification process for IEC 61850ed.2 in Saitel DP CPU866e is ongoing two months ago. Is it done now?
If it is can you post those documents here?
Thank you.
Best Regards,
Milica Repac
Tags (3)
  • iec 61850
  • Saitel DP
Iván_González
Lieutenant
Posted: ‎2021-01-13 01:07 AM
4356
Hello Milica,
Unfortunately, during testing some issues were detected and the christmas holiday period has impacted the corrections and re-testing. I'll keep you posted on any updates. Expecting to have good news in a couple of weeks for the server certification.
Iván_González
Lieutenant
Posted: ‎2021-04-06 04:16 AM
2
4341
Hi there,
It has been a tough process, but at long last here is the server certificate for IEC61850ed.2 of Saitel DP. We are now working on the client certification as well.
Tags (3)
  • iec61850
  • Saitel DP
Iván_González
Lieutenant
Posted: ‎2021-05-06 06:14 AM
1
4327
I am glad to announce that we have successfully passed also the level A client certification for Saitel DP in IEC 61850ed.2. In the coming weeks we should be receiving the certifate & reports from DNV-GL
Tags (3)
  • iec61850
  • Saitel DP
Iván_González
Lieutenant
Posted: ‎2021-05-21 01:11 AM
Posting the final certficate of compliance with IEC 61850Ed2 client for Saitel DP
Tags (3)
  • iec61850
  • Saitel DP
