Relay Aux - Fast Trip and Lockout Relay
Protection & Control
Showing results forย
Did you mean:ย
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • Relay Aux - Fast Trip and Lockout Relay
Araceli_Monje
Araceli_Monje Mentor
60
Arun-kumar_PS
Arun-kumar_PS Mentor
26
JuanRayo
JuanRayo Mentor
24
Back to Protection & Control
SESA528
SESA528 Contributor
Contributor
Posted: โ€Ž2020-04-09 07:35 AM . Last Modified: โ€Ž2023-05-23 07:37 AM
8
2747
HI admin,
Do you have any documents about relay REL91280 (Fast Trip and Lockout Relay)?
If Yes. Pls share with me. Thanks very much
  • Application cases
HenriGRASSET
HenriGRASSET Champion
Champion
Posted: โ€Ž2020-04-14 07:45 AM
3
2727
It is only an auxiliary relay.
What is missing in?:
https://download.schneider-electric.com/files?p_enDocType=Catalog&p_File_Name=RelayAux_NRJED113433EN...
Regards
EDISON Expert
HenriGRASSET
Champion
Posted: โ€Ž2020-04-14 11:26 PM
1
2720
In auxiliary relays, there is no power supply, it is an electro-mechanical device.
For example, the battery "+" is connected on one side of the protection relay contact; Its other pin is connected to the "+" of the auxiliary relay and its "-" to the 0V of the battery.
When the protection relay output contact closes, it energizes the auxiliary relay coil that closes some of its contacts.
EDISON Expert
Replies 8
Posted: โ€Ž2020-04-14 02:12 AM
2739
Hi the community members, can you help this member on this topic, please?
@HenriGRASSET or @Denis-Parnaland  do you think you can advise on this topic?
Have a nice day.
HenriGRASSET
Champion
Posted: โ€Ž2020-04-14 05:21 AM
6
2734
Hello Nedjma,
I do not find any link to the original topic.
What is the issue?
EDISON Expert
HenriGRASSET
Champion
Posted: โ€Ž2020-04-14 05:25 AM
5
2733
Just to be more precise:
If it is just documents, GOOGLE knows as much as us.
Type REL91280 and it will show our page with docs in.
https://www.se.com/ww/en/product/REL91280/relayaux---fast-trip-and-lockout-relay---8-c-o---pick-up-t...
Regards
EDISON Expert
SESA528
SESA528 Contributor
Contributor
Posted: โ€Ž2020-04-14 07:37 AM
4
2729
HI @Anonymous user ,
HI @HenriGRASSET ,
I need instruction sheet, user manual, installation manual.
Pls help me. Thanks very much
HenriGRASSET
Champion
3
2728
Regards
EDISON Expert
SESA528
SESA528 Contributor
Contributor
Posted: โ€Ž2020-04-14 08:06 AM
2
2724
Hi @HenriGRASSET ,
I need pin power supply? with REL91280 i don't know which pin power supply?
HenriGRASSET
Champion
1
2721
EDISON Expert
SESA528
SESA528 Contributor
Contributor
Posted: โ€Ž2020-04-20 11:31 AM
Hi @HenriGRASSET ,
OK. I understand. Thanks for your information. ๐Ÿ™‚ ๐Ÿ˜‰
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
