Protection Realy(P5), Windows 11 Compatibility Inquiries
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Protection Realy(P5), Windows 11 Compatibility Inquiries
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
PowerLogic P3
Back to Protection & Control
chambit.kim
chambit.kim Cadet
Cadet
Posted: ‎2024-11-13 04:09 PM . Last Modified: ‎2024-11-13 04:10 PM
736
Hello, Always take care of your health and be full of good things.
I would like to ask you something.
Please refer to the information below.
1. Test conditions
    1) Computer specifications: windows 11pro, 23H2, 64bit
    2) P5 relay USB communication connection completed
2. Confirmed matters
    - Control, Protection, and other Setting have no problem with modifications.
3. Questions
    - As shown in the picture attached above, I applied a voltage, but Virtual Injection does not work.
4. Request
   - I want to use the Virtual Injection job normally.
  • Thumbnail of PowerLogic P3
    PowerLogic
    PowerLogic P3
View products (1)
  • PowerLogic P5
Shaogang_WANG
Lt. Commander Shaogang_WANG Lt. Commander
Lt. Commander
Posted: ‎2024-11-13 07:27 PM
Hello  @chambit.kim
Normally there will be no compatibility issue for Easergy Pro running in Windows 11 OS.
The virtual measurement injection in Easergy Pro depends on the WinPCap tool, which can be installed when install Easergy Pro together.
Could you please check that?
1) whether the WinPCap tool has been installed successfully in your computer?
2)whether the NPCap tool is not installed in your computer? if NPCap is there, please remove it, and re-install the Easergy Pro with WinPCap, and PC reboot is required.
3) please make sure the firewall is disabled. (Trellix)
Shaogang_WANG
Lt. Commander
Hello  @chambit.kim
